이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Depress the top of the battery cover, and pull downwards towards the base of the phone.
Remove the battery by levering the battery out, using the cut just below the camera.
Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
Work the opening tool around the border of the camera and speaker cover, until it comes loose.
Using the opening tool, pry the back panel from the front panel.
Work your way around the phone until the panels separate evenly.
이 단계에 사용된 도구:Tweezers$4.99-
The camera's connection to the motherboard is shown here.
Using the tweezers, disconnect the port, shown here in the picture.
