주요 콘텐츠로 건너뛰기
Huawei Mate 10 Fingerprint Sensor Replacement
필요한 것
  1. Huawei Mate 10 Fingerprint Sensor Replacement, Remove the back cover: 1 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement, Remove the back cover: 1 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement, Remove the back cover: 1 단계, 이미지 3/3
    • Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone.
    • While you wait, note the location of the adhesive holding the back cover in place.
  2. Huawei Mate 10 Fingerprint Sensor Replacement: 2 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 2 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 2 단계, 이미지 3/3
    • Place a suction cup near the bottom edge of the back cover, on the right side (opposite the speaker grille) of the USB-C charging port, above the microphone hole.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. If all else fails, you can superglue the suction cup to the back cover.
    • Pull on the suction cup with strong, steady force to create a gap.
    • Due to the adhesive's strength, this is very difficult and may take multiple attempts. If you can't create a gap, re-apply heat and try again.
    • Insert the point of an opening pick into the gap.
  3. Huawei Mate 10 Fingerprint Sensor Replacement: 3 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 3 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 3 단계, 이미지 3/3
    • Slide the pick along the bottom edge and around the bottom-left corner, slicing through the adhesive.
    • If the adhesive feels tacky and difficult to slice, re-apply heat to the edge and try again.
    • Leave an opening pick in the seam to prevent the edge from re-sealing.
  4. Huawei Mate 10 Fingerprint Sensor Replacement: 4 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 4 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 4 단계, 이미지 3/3
    • Apply a heated iOpener to the left edge of the phone.
    • Use an opening pick to slice through the adhesive on the left edge of the phone.
    • The adhesive is very thick in some areas. Sustained exposure to heat will help weaken the stubborn adhesive. Take your time, and apply heat liberally.
  5. Huawei Mate 10 Fingerprint Sensor Replacement: 5 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement: 5 단계, 이미지 2/2
    • Continue heating and slicing through the remaining edges, leaving opening picks in the seams to prevent the adhesive from re-sealing.
  6. Huawei Mate 10 Fingerprint Sensor Replacement: 6 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 6 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 6 단계, 이미지 3/3
    • After you cut through the adhesive around the entire perimeter of the back cover, begin to lift it away from the phone.
    • Use an opening pick to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  7. Huawei Mate 10 Fingerprint Sensor Replacement, Prep the phone for a new back cover: 7 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement, Prep the phone for a new back cover: 7 단계, 이미지 2/2
    • Before you install a replacement back cover, be sure to remove all traces of perimeter adhesive from the phone frame.
    • If you are re-using the back cover, carefully remove all traces of adhesive from the back cover.
    • The glass back cover is fragile and prone to cracking. Don't apply uneven pressure to the back cover as you clean.
    • You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
  8. Huawei Mate 10 Fingerprint Sensor Replacement: 8 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement: 8 단계, 이미지 2/2
    • If your replacement back cover did not come with a flash diffuser or camera bezel, you will need to transfer them from your old cover to the new one.
    • Apply a heated iOpener directly over the bezels for a minute.
    • Use an opening pick to slice around the flash diffuser to loosen the adhesive.
    • The flash diffuser is made of plastic and cracks easily. Be sure to slice around the flash completely before you pry it off.
    • Use an opening tool to pry up and remove the camera bezel.
    • Transfer the parts to your replacement cover.
  9. Huawei Mate 10 Fingerprint Sensor Replacement, Remove the plastic bracket: 9 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement, Remove the plastic bracket: 9 단계, 이미지 2/2
    • The next two steps show how to remove the heat dissipation layer, along with its plastic bracket.
    • Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
    • One screw lies beneath a white sticker. Remove the sticker.
    • Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
  10. Huawei Mate 10 Fingerprint Sensor Replacement: 10 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 10 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 10 단계, 이미지 3/3
    • Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
    • Pull the plastic bracket away from the top edge of the phone.
    • Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
    • Remove the plastic bracket along with the heat dissipation layer.
  11. Huawei Mate 10 Fingerprint Sensor Replacement, Disconnect the battery: 11 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement, Disconnect the battery: 11 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  12. Huawei Mate 10 Fingerprint Sensor Replacement, Disconnect the interconnect cable: 12 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement, Disconnect the interconnect cable: 12 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Huawei Mate 10 Fingerprint Sensor Replacement: 13 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement: 13 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the fingerprint extension cable from its motherboard socket.
  14. Huawei Mate 10 Fingerprint Sensor Replacement, Remove the loudspeaker: 14 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement, Remove the loudspeaker: 14 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the white antenna cable from the bottom of the phone.
  15. Huawei Mate 10 Fingerprint Sensor Replacement: 15 단계, 이미지 1/1
    • Remove the six 3.4 mm Phillips screws holding the loudspeaker in place.
  16. Huawei Mate 10 Fingerprint Sensor Replacement: 16 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement: 16 단계, 이미지 2/2
    • The loudspeaker is still held in place by adhesive and clips.
    • Insert an opening pick underneath the right edge of the loudspeaker assembly.
    • Carefully slide the opening pick under the right half of the assembly to loosen the clips.
  17. Huawei Mate 10 Fingerprint Sensor Replacement: 17 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 17 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 17 단계, 이미지 3/3
    • Grasp the loosened edge of the loudspeaker and gently pull the assembly away from the bottom edge of the phone.
    • You may need to wiggle the assembly a little to loosen it from the frame.
    • Remove the loudspeaker.
  18. Huawei Mate 10 Fingerprint Sensor Replacement, Remove the daughterboard: 18 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement, Remove the daughterboard: 18 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement, Remove the daughterboard: 18 단계, 이미지 3/3
    • Insert the point of a spudger in one of the notches along the bottom edge of the daughterboard.
    • Push the daughterboard away from the bottom of the phone to loosen the board.
    • Repeat the process with a second notch to fully release the daughterboard.
  19. Huawei Mate 10 Fingerprint Sensor Replacement: 19 단계, 이미지 1/1
    • Remove the daughterboard.
  20. Huawei Mate 10 Fingerprint Sensor Replacement, Fingerprint Sensor: 20 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement, Fingerprint Sensor: 20 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket.
  21. Huawei Mate 10 Fingerprint Sensor Replacement: 21 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 21 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 21 단계, 이미지 3/3
    • Grasp the display cable with your fingers and gently pull it away from the phone frame.
  22. Huawei Mate 10 Fingerprint Sensor Replacement: 22 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 22 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 22 단계, 이미지 3/3
    • Use tweezers to peel the tape covering the fingerprint sensor cable connector near the bottom edge of the phone.
    • The cable is held in place with a ZIF socket.
    • Use the point of a spudger to flip up the gray bar on the socket to unlock the cable.
  23. Huawei Mate 10 Fingerprint Sensor Replacement: 23 단계, 이미지 1/2 Huawei Mate 10 Fingerprint Sensor Replacement: 23 단계, 이미지 2/2
    • Use tweezers to grasp the cable's brown pull tab and pull the cable out of the socket.
    • To reinstall the fingerprint sensor cable:
    • Align and push the cable back into the connector, up to the white line marked on the cable.
    • Carefully flip the gray bar on the socket down to lock the cable in place.
  24. Huawei Mate 10 Fingerprint Sensor Replacement: 24 단계, 이미지 1/1
    • The next steps show how to remove the heavily glued screen from the phone. While it is possible to replace the top glass alone, it is very difficult to accomplish without damaging the LCD.
    • Apply a heated iOpener to the left edge of the phone for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used. Since you don't need to worry about overheating the battery or screen, you can apply more heat than usual.
  25. Huawei Mate 10 Fingerprint Sensor Replacement: 25 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 25 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 25 단계, 이미지 3/3
    • Place a suction cup near the bottom left corner of the phone. The edge there has slightly thinner adhesive.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert an opening pick in the gap.
    • Depending on how old your phone is, creating this initial gap may be very difficult. Here are some things you can try if you're having trouble:
    • Repeat the heating and pulling process multiple times to soften the adhesive.
    • Use a playing card instead of an opening pick to insert in the gap.
    • Try heating and prying at a different location.
    • Use a Jimmy to make the initial entry. Be careful working with metal tools, as they will scratch the frame and chip the glass screen.
  26. Huawei Mate 10 Fingerprint Sensor Replacement: 26 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 26 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 26 단계, 이미지 3/3
    • Once you've made the initial entry, slice through the left, top, and right phone edges. Apply heat to help soften the adhesive.
    • The top edge has adhesive that's as thick as the bezel. Make sure to slice through all of the adhesive.
  27. Huawei Mate 10 Fingerprint Sensor Replacement: 27 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 27 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 27 단계, 이미지 3/3
    • As you slice through the bottom edge, be careful not to slice near the right of the fingerprint sensor. It contains the sensor ribbon, which is prone to damage.
    • Slice through the bottom edge of the phone, making sure to skip the fingerprint sensor area as marked.
  28. Huawei Mate 10 Fingerprint Sensor Replacement: 28 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 28 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 28 단계, 이미지 3/3
    • Once you have sliced around the perimeter, grasp the screen from the top corners and lift up.
    • Use an opening pick to slice through any remaining adhesive holding onto the screen.
    • Carefully thread the fingerprint sensor cable through its frame cutout.
    • Thread the display cable through its frame cutout.
  29. Huawei Mate 10 Fingerprint Sensor Replacement: 29 단계, 이미지 1/1
    • Remove the screen.
    • You may need to transfer the fingerprint sensor to your new screen. Follow the next step to remove the fingerprint sensor.
  30. Huawei Mate 10 Fingerprint Sensor Replacement: 30 단계, 이미지 1/3 Huawei Mate 10 Fingerprint Sensor Replacement: 30 단계, 이미지 2/3 Huawei Mate 10 Fingerprint Sensor Replacement: 30 단계, 이미지 3/3
    • Position your finger or the flat end of a spudger on the fingerprint sensor's backside and push gently to dislodge the sensor.
    • Carefully thread the sensor cable through the screen's cutout.
    • Remove the fingerprint sensor.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
Arthur Shi
회원 가입일: 01/03/18
249,670 평판
안내서 503개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 1,910
