주요 콘텐츠로 건너뛰기
Huawei Mate 8 Back Cover Replacement
필요한 것
  1. Huawei Mate 8 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei Mate 8 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Back Cover Replacement: 2 단계, 이미지 1/1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Back Cover Replacement: 3 단계, 이미지 1/2 Huawei Mate 8 Back Cover Replacement: 3 단계, 이미지 2/2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Back Cover Replacement: 4 단계, 이미지 1/3 Huawei Mate 8 Back Cover Replacement: 4 단계, 이미지 2/3 Huawei Mate 8 Back Cover Replacement: 4 단계, 이미지 3/3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,220 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,816개 작성하였습니다
댓글 2개
Question: If for some reason I accidentally cut the flex cable of the fingerprint sensor, can I replace the part? or it is like TouchID?
[deleted] - 답글
I agree, easy if if you own this suction device and know WTF a spudger is. Otherwise, what? :/
404cameljockey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,970
