주요 콘텐츠로 건너뛰기
Huawei Mate 9 Back Cover Replacement
필요한 것
  1. Huawei Mate 9 Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Huawei Mate 9 Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Huawei Mate 9 Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Back Cover Replacement: 3 단계, 이미지 2개 중 1개 Huawei Mate 9 Back Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
123,935 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,131개를 작성함
댓글 한 개
So apparently they must have welded my phone together with some unknown super exotic alloy from another planet. After spending nearly an hour removing the 2 screws at the bottom of the phone using a borrowed IFIXIT tool kit from a friend I proceeded to destroy a guitar pick, 1 heavy duty guitar pick looking thingy, and 2 separating tools from the kit and all I’ve succeeded in doing so far was breaking the bottom of the back cover of my phone. All I wanted to do was save the 50 bucks the guy quoted me to fix the charging port but now I’m thinking that’s a pretty good deal after you add up the cost of repair parts for demolishing my phone. $28.00 for a new back cover that will take 6 weeks to get , a new digitizer has to be over a hundred bucks, and how do you put a price on the frustration this is going to be if I keep going? Do yourself a favor and have someone else work on your device while it can still be saved. These 2 suction cups seem to be stronger than me and I’m jacked!!!
Randy Simpson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 26
지난 30일: 60
전체 시간: 5,454
