주요 콘텐츠로 건너뛰기
Huawei Mate 9 Rear and Front Camera Replacement
필요한 것
  1. Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 1 단계, 이미지 3개 중 1개 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 1 단계, 이미지 3개 중 2개 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 1 단계, 이미지 3개 중 3개
    • Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Rear and Front Camera Replacement: 2 단계, 이미지 3개 중 1개 Huawei Mate 9 Rear and Front Camera Replacement: 2 단계, 이미지 3개 중 2개 Huawei Mate 9 Rear and Front Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Rear and Front Camera Replacement: 3 단계, 이미지 2개 중 1개 Huawei Mate 9 Rear and Front Camera Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Rear and Front Camera Replacement: 4 단계, 이미지 2개 중 1개 Huawei Mate 9 Rear and Front Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Using a spudger, disconnect the battery connector.
    • After disconnecting the battery connector, you can now completely remove the back cover.
  5. Huawei Mate 9 Rear and Front Camera Replacement: 5 단계, 이미지 3개 중 1개 Huawei Mate 9 Rear and Front Camera Replacement: 5 단계, 이미지 3개 중 2개 Huawei Mate 9 Rear and Front Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate.
    • After removing the metal plate, you can now remove and replace the rear camera from its slot.
  6. Huawei Mate 9 Rear and Front Camera Replacement: 6 단계, 이미지 2개 중 1개 Huawei Mate 9 Rear and Front Camera Replacement: 6 단계, 이미지 2개 중 2개
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rogelio Ramirez
회원 가입일: 06/25/17
539 평판
안내서 3개를 작성함
UC Davis, Team S7-G8, Lore Fall 2018 UC Davis, Team S7-G8, Lore Fall 2018 회원
UCD-LORE-F18S7G8
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 23
전체 시간: 2,279
