주요 콘텐츠로 건너뛰기
Huawei Media Pad M3 Lite Display Replacement
필요한 것
  1. Huawei Media Pad M3 Lite Display Replacement, Heat up the tablet: 1 단계, 이미지 1개 중 1개
    • Choose a side of the tablet to start; i took the one with the home button and heat it with the iOpener
    • Heat up the rest of the tablet
  2. Huawei Media Pad M3 Lite Display Replacement, First side of the tablet: 2 단계, 이미지 3개 중 1개 Huawei Media Pad M3 Lite Display Replacement, First side of the tablet: 2 단계, 이미지 3개 중 2개 Huawei Media Pad M3 Lite Display Replacement, First side of the tablet: 2 단계, 이미지 3개 중 3개
    • Put the suction handle roughly where the home button is and try to lift the display so you can slide with a pick between the display and the back cover. Be paitent it may take a while.
    • Take a second pick and try to get between display and the back cover
    • Once you are in with this pick move the pick from the middle to one of the edges
  3. Huawei Media Pad M3 Lite Display Replacement, Second side: 3 단계, 이미지 2개 중 1개 Huawei Media Pad M3 Lite Display Replacement, Second side: 3 단계, 이미지 2개 중 2개
    • Take the next pick and move it to the next corner of the tablet
  4. Huawei Media Pad M3 Lite Display Replacement, Third side: 4 단계, 이미지 3개 중 1개 Huawei Media Pad M3 Lite Display Replacement, Third side: 4 단계, 이미지 3개 중 2개 Huawei Media Pad M3 Lite Display Replacement, Third side: 4 단계, 이미지 3개 중 3개
    • Insert another pick and move along the whole side of the tablet up to the next edge of the tablet
  5. Huawei Media Pad M3 Lite Display Replacement, Last side: 5 단계, 이미지 2개 중 1개 Huawei Media Pad M3 Lite Display Replacement, Last side: 5 단계, 이미지 2개 중 2개
    • Same procedure as on the other sides. Take another pick and move it to the next corner of the tablet
  6. Huawei Media Pad M3 Lite Display Replacement, Lift the display: 6 단계, 이미지 3개 중 1개 Huawei Media Pad M3 Lite Display Replacement, Lift the display: 6 단계, 이미지 3개 중 2개 Huawei Media Pad M3 Lite Display Replacement, Lift the display: 6 단계, 이미지 3개 중 3개
    • With the tablet in standard landscape orientation lift the display to the right.
    • Attention: There are cables on the right side connecting display and motherboard
  7. Huawei Media Pad M3 Lite Display Replacement, Removing the screws: 7 단계, 이미지 1개 중 1개
    • Remove one screw from the battery connector plate
    • Remove two screws from the display connector plate
  8. Huawei Media Pad M3 Lite Display Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Huawei Media Pad M3 Lite Display Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Huawei Media Pad M3 Lite Display Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the battery connector plate.
    • Use a spudger to disconnect the battery.
  9. Huawei Media Pad M3 Lite Display Replacement, Disconnect the Display: 9 단계, 이미지 3개 중 1개 Huawei Media Pad M3 Lite Display Replacement, Disconnect the Display: 9 단계, 이미지 3개 중 2개 Huawei Media Pad M3 Lite Display Replacement, Disconnect the Display: 9 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to remove the display connector plate
    • Use a spudger to disconnect the display
결론
작성자
2다른 기여자 명과 함께
Benjamin Haase
회원 가입일: 03/20/23
343 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 438
