주요 콘텐츠로 건너뛰기
Huawei MediaPad M3 Rear Camera Replacement
필요한 것
  1. Huawei MediaPad M3 Rear Camera Replacement, Display Assembly: 1 단계, 이미지 1/2 Huawei MediaPad M3 Rear Camera Replacement, Display Assembly: 1 단계, 이미지 2/2
    • Use a heat gun to heat the display. It may take up to 30 seconds.
    • Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
  2. Huawei MediaPad M3 Rear Camera Replacement: 2 단계, 이미지 1/2 Huawei MediaPad M3 Rear Camera Replacement: 2 단계, 이미지 2/2
    • Open the display carefully.
    • Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
  3. Huawei MediaPad M3 Rear Camera Replacement: 3 단계, 이미지 1/2 Huawei MediaPad M3 Rear Camera Replacement: 3 단계, 이미지 2/2
    • After removing the two screws, use your hand to take out the silver metal bracket.
  4. Huawei MediaPad M3 Rear Camera Replacement: 4 단계, 이미지 1/3 Huawei MediaPad M3 Rear Camera Replacement: 4 단계, 이미지 2/3 Huawei MediaPad M3 Rear Camera Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to disconnect the two ribbon cable connectors.
  5. Huawei MediaPad M3 Rear Camera Replacement: 5 단계, 이미지 1/2 Huawei MediaPad M3 Rear Camera Replacement: 5 단계, 이미지 2/2
    • Remove the display assembly from the device.
  6. Huawei MediaPad M3 Rear Camera Replacement, Front Camera: 6 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the six 3.0mm screws.
  7. Huawei MediaPad M3 Rear Camera Replacement: 7 단계, 이미지 1/1
    • Use your hand to remove the silver metal bracket.
  8. Huawei MediaPad M3 Rear Camera Replacement: 8 단계, 이미지 1/2 Huawei MediaPad M3 Rear Camera Replacement: 8 단계, 이미지 2/2
    • Use your hand to remove the two black plastic covers.
  9. Huawei MediaPad M3 Rear Camera Replacement: 9 단계, 이미지 1/3 Huawei MediaPad M3 Rear Camera Replacement: 9 단계, 이미지 2/3 Huawei MediaPad M3 Rear Camera Replacement: 9 단계, 이미지 3/3
    • Use a plastic opening tool to remove the front camera.
  10. Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: 10 단계, 이미지 1/3 Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: 10 단계, 이미지 2/3 Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: 10 단계, 이미지 3/3
    • Disconnect and remove the camera from the motherboard.
결론
Kefan Lin
회원 가입일: 10/01/19
515 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 11
전체 시간: 357
