주요 콘텐츠로 건너뛰기
Huawei MediaPad S7-301u Battery Replacement
필요한 것
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: 1 단계, 이미지 1/3 Huawei MediaPad S7-301u Battery Replacement, Battery: 1 단계, 이미지 2/3 Huawei MediaPad S7-301u Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: 3 단계, 이미지 1/3 Huawei MediaPad S7-301u Battery Replacement: 3 단계, 이미지 2/3 Huawei MediaPad S7-301u Battery Replacement: 3 단계, 이미지 3/3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: 4 단계, 이미지 1/3 Huawei MediaPad S7-301u Battery Replacement: 4 단계, 이미지 2/3 Huawei MediaPad S7-301u Battery Replacement: 4 단계, 이미지 3/3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Miguel Lugo
회원 가입일: 09/26/17
598 평판
안내서 3개 작성하였습니다
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G5
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 7,066
