주요 콘텐츠로 건너뛰기
Huawei MediaPad S7-301u Battery Replacement
필요한 것
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: 3 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Battery Replacement: 3 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: 4 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Battery Replacement: 4 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Miguel Lugo
회원 가입일: 09/26/17
598 평판
안내서 3개를 작성함
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G5
4 회원들
안내서 8개를 작성함
1가이드 댓글
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 7,506
