소개
The battery is an essential part of the device. A battery that is in use for a long time can be worn out or malfunction. If you notice your battery drains fast or doesn’t charge at all, then you know that you have a bad battery that needs to be replaced. Another sign of a bad battery is a swollen or deformed battery. A swollen battery can be hazardous because it can leak dangerous chemicals. Always wear proper protection while handling batteries and follow the manufacturer's safety procedure.
The Huawei HB3G1H internal battery is the one that needs to be replace in this device. After the replacement; if it’s still not working, then the next step is to check other components of the device such as motherboard or any other wires that may be disconnected.
필요한 것
Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
