주요 콘텐츠로 건너뛰기
Huawei MediaPad S7-301u Screen Replacement
필요한 것
  1. Huawei MediaPad S7-301u Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Screen Replacement: 3 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Screen Replacement: 3 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Screen Replacement: 4 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Screen Replacement: 4 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Screen Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Screen Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Screen Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Screen Replacement: 6 단계, 이미지 3개 중 1개 Huawei MediaPad S7-301u Screen Replacement: 6 단계, 이미지 3개 중 2개 Huawei MediaPad S7-301u Screen Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Screen Replacement: 7 단계, 이미지 2개 중 1개 Huawei MediaPad S7-301u Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Screen Replacement, Screen: 8 단계, 이미지 1개 중 1개
    • Remove the 7 2mm screws for on the metal frame. Use a J000 screwdriver.
  9. Huawei MediaPad S7-301u Screen Replacement: 9 단계, 이미지 2개 중 1개 Huawei MediaPad S7-301u Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully remove the LCD from the front glass casing.
    • While separating the LCD from the device, be careful not to introduce any debris.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Miguel Lugo
회원 가입일: 09/26/17
598 평판
안내서 3개를 작성함
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 2,953
