주요 콘텐츠로 건너뛰기
Huawei P10 Lite Back cover Replacement
필요한 것
  1. Huawei P10 Lite Back cover Replacement, Back cover: 1 단계, 이미지 1/3 Huawei P10 Lite Back cover Replacement, Back cover: 1 단계, 이미지 2/3 Huawei P10 Lite Back cover Replacement, Back cover: 1 단계, 이미지 3/3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Back cover Replacement: 2 단계, 이미지 1/3 Huawei P10 Lite Back cover Replacement: 2 단계, 이미지 2/3 Huawei P10 Lite Back cover Replacement: 2 단계, 이미지 3/3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Back cover Replacement: 3 단계, 이미지 1/2 Huawei P10 Lite Back cover Replacement: 3 단계, 이미지 2/2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Back cover Replacement: 4 단계, 이미지 1/2 Huawei P10 Lite Back cover Replacement: 4 단계, 이미지 2/2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,064 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,766개 작성하였습니다
댓글 6개
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - 답글
You need to warm the adhesive so it can be loose
Adwell Cellular -
What adhesive should I use? Thank you!
Calin GV - 답글
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - 답글
Can you send me please back cover.
I'm from Nepal .
Md Usman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 109
전체 시간: 38,435
