주요 콘텐츠로 건너뛰기
Huawei P10 Lite Loudspeaker / Vibration Motor Replacement
필요한 것
  1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: 1 단계, 이미지 1/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: 1 단계, 이미지 2/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: 1 단계, 이미지 3/3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 2 단계, 이미지 1/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 2 단계, 이미지 2/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 2 단계, 이미지 3/3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 3 단계, 이미지 1/2 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 3 단계, 이미지 2/2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 4 단계, 이미지 1/2 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 4 단계, 이미지 2/2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: 5 단계, 이미지 1/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: 5 단계, 이미지 2/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: 5 단계, 이미지 3/3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Loudspeaker / Vibration Motor: 6 단계, 이미지 1/1
    • Remove the seven Philipps #000 screws.
  7. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 7 단계, 이미지 1/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 7 단계, 이미지 2/3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 7 단계, 이미지 3/3
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  8. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 8 단계, 이미지 1/2 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: 8 단계, 이미지 2/2
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
다른 2명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,250 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
is it necessary to disconnect the finger print sensor flex cable in order to remove/replace the loudspeaker, or is just a precaution!?
Ricardo Mendes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 4,223
