주요 콘텐츠로 건너뛰기
소개
Use this guide to replace the rear camera in your Huawei P10 Lite smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive. Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in. If the adhesive is hard to cut, use an iOpener to loosen it.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone. Flip the rear cover over to the right side of the phone. Flip the rear cover over to the right side of the phone.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Use a pair of tweezers to remove the sticker. Remove the two Phillips #00 screws.
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Use tweezers to remove the mainboard shield. Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Remove the Phillips screw holding the battery connector plate in place. Remove the battery connector plate. Use the flat end of a spudger to disconnect the battery flex cable.
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Use the flat end of a spudger to disconnect the rear camera flex cable. Remove the rear camera.
    • Use the flat end of a spudger to disconnect the rear camera flex cable.
    • Remove the rear camera.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
회원 가입일: 2016년 11월 23일
90,467 평판
안내서 375개 작성하였습니다
iFixit iFixit 회원
Community
136 회원들
안내서 16,002개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 20
전체 시간: 1,558
