주요 콘텐츠로 건너뛰기
Huawei P20 Camera Lens Replacement
필요한 것
    • If you have any questions, feel free to ask them!
결론
다른 5명이 해당 안내서를 완성하였습니다.
Pieter
회원 가입일: 11/10/15
494 평판
안내서 1개 작성함
댓글 5개
Thanks, you helpt me well with this one!
Kristof Ven - 답글
Did this step by step, making sure not to touch the lense. Although, quality of photos are worse than before for some reason
Cole VHelm - 답글
Maybe the new lens is of a lower quality?
Pieter -
My lens hasn't broken it just has a smudge on the inside, can you do this and then use the same glue to put the lens back on. Or do you still recommend replacing the entire lens?
Luke Hardy - 답글
Hi Luke, Sorry for the late response. I had not seen your reply. It’s definitely going to be hard if you want to remove the glass in one piece.
Please let us know if it worked out for you. Good luck
Pieter -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 25
전체 시간: 10,100
