소개
This guide will help you replace the battery inside your Huawei P8 Lite phone.
필요한 것
이 단계에 사용된 도구:T5 Torx Screwdriver$9.99
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
Locate the adhesive strip underneath the battery. Gently pull on the strip to loosen it enough to remove the battery from the device.
다른 2명이 해당 안내서를 완성하였습니다.
