이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Spudger$2.99-
Using the Spudger, begin by removing both of the SIM slots from the side of the device.
Then remove the back cover of the device with the Spudger. To prevent damage to the back cover, begin removing the cover half an inch to the right of the headphone jack and continue prying around the perimeter of the device.
이 단계에 사용된 도구:T5 Torx Screwdriver$9.99-
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
Use the Spudger to gently remove the Loudspeaker from the device. Place the replacement Loudspeaker into the device and follow these steps in reverse order to reassemble the device.
Once the motherboard is removed use the Spudger to remove the Front Camera.
다른 3명이 해당 안내서를 완성하였습니다.
