주요 콘텐츠로 건너뛰기
Huawei P8 Lite Motherboard Replacement
필요한 것
  1. Huawei P8 Lite Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei P8 Lite Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Motherboard Replacement: 2 단계, 이미지 1/3 Huawei P8 Lite Motherboard Replacement: 2 단계, 이미지 2/3 Huawei P8 Lite Motherboard Replacement: 2 단계, 이미지 3/3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Motherboard Replacement, Loudspeaker: 3 단계, 이미지 1/1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Huawei P8 Lite Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Huawei P8 Lite Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the three Phillips #00 screws that hold the metal plate in place.
    • Remove the metal plate with a tweezer.
    • Unplug the battery flex connector with a spudger.
  7. Huawei P8 Lite Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the two Torx T5 screws.
    • If there is a tamper evident sticker over your screws remove them to properly seat your driver.
    • Remove the five Phillips #00 screws.
  8. Huawei P8 Lite Motherboard Replacement: 8 단계, 이미지 1/2 Huawei P8 Lite Motherboard Replacement: 8 단계, 이미지 2/2
    • Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
    • Then remove the top cover.
  9. Huawei P8 Lite Motherboard Replacement: 9 단계, 이미지 1/3 Huawei P8 Lite Motherboard Replacement: 9 단계, 이미지 2/3 Huawei P8 Lite Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the SIM card and SD card trays.
    • Disconnect the three plug connectors and one ZIF connector.
    • Unlock the ZIF connector by lifting the small black plastic lever.
  10. Huawei P8 Lite Motherboard Replacement: 10 단계, 이미지 1/3 Huawei P8 Lite Motherboard Replacement: 10 단계, 이미지 2/3 Huawei P8 Lite Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove the volume and power button cable.
    • Take out the motherboard by lifting the bottom part first.
    • Pay attention to the cables, so they don't rip when staying stuck to the motherboard.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If this thermal pad broke or is too dried out you might want to replace it with a new one.
결론
To reassemble your device, follow these instructions in reverse order and apply adhesive where necessary.
다른 9명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,588 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 한 개
My p8 lite is not connecting to mobile networks unless im in town onyl whats the prob
Mhofu Powers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 38
전체 시간: 10,254
