주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei P9 Back Cover
필요한 것
  1. Huawei P9 Back Cover, Back Cover: 1 단계, 이미지 3개 중 1개 Huawei P9 Back Cover, Back Cover: 1 단계, 이미지 3개 중 2개 Huawei P9 Back Cover, Back Cover: 1 단계, 이미지 3개 중 3개
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Back Cover: 2 단계, 이미지 2개 중 1개 Huawei P9 Back Cover: 2 단계, 이미지 2개 중 2개
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Back Cover, Fingerprint sensor: 3 단계, 이미지 2개 중 1개 Huawei P9 Back Cover, Fingerprint sensor: 3 단계, 이미지 2개 중 2개
    • Disconnect the fingerprint sensor using a spudger.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
130,284 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
1가이드 댓글
I cant open the phone
Chizu - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 112
전체 시간: 9,681
