주요 콘텐츠로 건너뛰기
Huawei P9 Charging Board Replacement
필요한 것
  1. Huawei P9 Charging Board Replacement, Back Cover: 1 단계, 이미지 1/3 Huawei P9 Charging Board Replacement, Back Cover: 1 단계, 이미지 2/3 Huawei P9 Charging Board Replacement, Back Cover: 1 단계, 이미지 3/3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Charging Board Replacement: 2 단계, 이미지 1/2 Huawei P9 Charging Board Replacement: 2 단계, 이미지 2/2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Charging Board Replacement, Fingerprint sensor: 3 단계, 이미지 1/2 Huawei P9 Charging Board Replacement, Fingerprint sensor: 3 단계, 이미지 2/2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Charging Board Replacement, lower section: 4 단계, 이미지 1/3 Huawei P9 Charging Board Replacement, lower section: 4 단계, 이미지 2/3 Huawei P9 Charging Board Replacement, lower section: 4 단계, 이미지 3/3
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Carefully remove the metal bracket.
    • Mind the adhesive underneath that might stick to the headphone connector.
  5. Huawei P9 Charging Board Replacement: 5 단계, 이미지 1/3 Huawei P9 Charging Board Replacement: 5 단계, 이미지 2/3 Huawei P9 Charging Board Replacement: 5 단계, 이미지 3/3
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  6. Huawei P9 Charging Board Replacement, Charging Board: 6 단계, 이미지 1/1
    • Now you can easily remove the charging board.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,205 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,767개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 7,133
