소개
Use this guide to replace the charging board in your Huawei P9 smartphone.
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Undo the three Phillips #00 screws.
Disconnect the loudspeaker flex connector.
Carefully remove the metal bracket.
거의 끝나갑니다!
결론
다른 8명이 해당 안내서를 완성하였습니다.
