주요 콘텐츠로 건너뛰기
Huawei P9 Headphone Jack Replacement
필요한 것
  1. Huawei P9 Headphone Jack Replacement, Back Cover: 1 단계, 이미지 1/3 Huawei P9 Headphone Jack Replacement, Back Cover: 1 단계, 이미지 2/3 Huawei P9 Headphone Jack Replacement, Back Cover: 1 단계, 이미지 3/3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Headphone Jack Replacement: 2 단계, 이미지 1/2 Huawei P9 Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: 3 단계, 이미지 1/2 Huawei P9 Headphone Jack Replacement, Fingerprint sensor: 3 단계, 이미지 2/2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Headphone Jack Replacement, Headphone Jack: 4 단계, 이미지 1/3 Huawei P9 Headphone Jack Replacement, Headphone Jack: 4 단계, 이미지 2/3 Huawei P9 Headphone Jack Replacement, Headphone Jack: 4 단계, 이미지 3/3
    • Remove the water indicator on top of the screw.
    • Undo the two Phillips #00 screws.
    • Remove metal bracket (mind the adhesive underneath).
  5. Huawei P9 Headphone Jack Replacement: 5 단계, 이미지 1/2 Huawei P9 Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Disconnect the flex cable and remove the headphone jack.
    • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
119,191 평판
안내서 189개 작성하였습니다
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,092개 작성하였습니다
댓글 한 개
questo procedimento funziona anche con il modello p9 plus? grazie per l’attenzione
abcde181 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 5,946
