주요 콘텐츠로 건너뛰기
Huawei P9 Lite Loudspeaker Replacement
필요한 것
  1. Huawei P9 Lite Loudspeaker Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei P9 Lite Loudspeaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
    What could you use instead of an opening pick??
    Alfredo - 답글
    Like, could a guitar pick wor? Or anything else?
    Alfredo - 답글
    A guitar pick will also do.
    Tobias Isakeit -
    what can still be used besides guitar pick
    Tarshia Thompson - 답글
    I had a hard time to open the back cover by opening pick. Then I used little, really little knife at first, and I continue to opening back cover using opening pick.
    Andy B - 답글
    Heating up aroud the finger sensor to loosen the square adhesive tape ..
    Hishamchohan - 답글
    If you do not have any picks, You can also adapt an old credit or utility card by cutting it in to thirds. Then with some fine emery or sand paper, rub a sharp point on the one edge of the card. This will help you get access to the clips that hold the rear cover on. The one i did yesterday had quite a lot of adhesive around the edge & around the finger print sensor. Another tip with an old credit card is to cut it in to narrow strips to insert in to where you have separated the cover from the frame to stop it getting stuck to the adhesive again.
    gazza667 - 답글
  2. Huawei P9 Lite Loudspeaker Replacement: 2 단계, 이미지 1/1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
    Most of the adhesive is around the fingerprint cell and on the battery itself. You can slowly pull the back cover from its side but make sure not to break it. Push the mediator or a longer piece of plastic under the back cover to slowly destroy the adhesive.
    Nicolas Combaret - 답글
    Slowly, slowly wins the day. Nicolas is right and comes off a charm. The most nerve wracking part of this longish repair.
    John Nordstrom - 답글
  3. Huawei P9 Lite Loudspeaker Replacement: 3 단계, 이미지 1/1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
    Hi! Im so sad! At the begginig of the operation i ve broken the white seal/connector that in one side is connected to the board and the other side is "glued" to the battery. Can someone help me? how can i solve this?? There is no image displayed on the screen. but there is vibration, sound, notifications... can someone help me please???
    Diogo - 답글
    What you broke is handling the NFC, and doesn’t have anything to do with the display. You probably damaged the ribbon right below the battery, since that’s what links the display to the motherboard.
    Polaris -
    Oups ! L’antenne NFC était solidement collée à l’intérieur de la coque et j’ai donc déchiré sa nappe en ouvrant la coque. Heureusement, je n’utilise pas les fonctions NFC et, à part cela, tout a l’air de fonctionner normalement.
    Michel Orban - 답글
  4. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: 4 단계, 이미지 1/3 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: 4 단계, 이미지 2/3 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: 4 단계, 이미지 3/3
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,588 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 3개
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - 답글
Same problem here. Any help?
fabio9999 -
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 10,204
