이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the loudspeaker in your Huawei P9 Lite.
필요한 것
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
On the bottom of the phone remove the following screws:
Three 2.9 mm Phillips #00 screws
Four 3.8 mm Phillips #00 screws
Now you can grab the loudspeaker unit and take it out.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 3개
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
Same problem here. Any help?
Sir hy how are you. Sir p9lite song speaker not working.
