주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Huawei P9 Lite Motherboard Shield Removal
필요한 것
  1. Huawei P9 Lite Motherboard Shield Removal, Back Cover: 1 단계, 이미지 1/2 Huawei P9 Lite Motherboard Shield Removal, Back Cover: 1 단계, 이미지 2/2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Motherboard Shield Removal: 2 단계, 이미지 1/1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Motherboard Shield Removal: 3 단계, 이미지 1/1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Motherboard Shield Removal, Motherboard Shield: 4 단계, 이미지 1/1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Motherboard Shield Removal: 5 단계, 이미지 1/2 Huawei P9 Lite Motherboard Shield Removal: 5 단계, 이미지 2/2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,226 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,519개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 5,950
