주요 콘텐츠로 건너뛰기
Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement
필요한 것
  1. Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement, Headphone Jack & Vibration Motor Assembly: 1 단계, 이미지 1/3 Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement, Headphone Jack & Vibration Motor Assembly: 1 단계, 이미지 2/3 Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement, Headphone Jack & Vibration Motor Assembly: 1 단계, 이미지 3/3
    • Remove back cover.
  2. Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement: 2 단계, 이미지 1/1
    • Remove small signal cable.
  3. Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement: 3 단계, 이미지 1/2 Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement: 3 단계, 이미지 2/2
    • Twist off those nine screws and remove the bracket.
  4. Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement: 4 단계, 이미지 1/3 Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement: 4 단계, 이미지 2/3 Huawei Phone P7 Headphone Jack & Vibration Motor Assembly Replacement: 4 단계, 이미지 3/3
    • There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,686
