주요 콘텐츠로 건너뛰기
Huawei Phone p7 Back Cover Replacement
필요한 것
  1. Huawei Phone p7 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Heat to melt the adhesive sticker under the back cover.
  2. Huawei Phone p7 Back Cover Replacement: 2 단계, 이미지 1/1
    • Place the suction cup and pull to open a gap between the back cover and the body.And then insert into the guitar pick and slide to cut the sticker.
    • Attention: Be careful with the bottom side because there is the battery flex cable.
  3. Huawei Phone p7 Back Cover Replacement: 3 단계, 이미지 1/1
    • Remove the back cover.
  4. Huawei Phone p7 Back Cover Replacement: 4 단계, 이미지 1/1
    • And you can replace with the new back cover.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 한 개
Is the nfc sensor in the back plate, because i broke the glass and i can see some antennas through the holes. And i think the exposure killed my nfc.
Yoran - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 11,514
