소개
The display screen is a vital part of the device. Seeing what you're doing on your phone helps to navigate each move you make in the correct order.
필요한 것
Remove the back cover of your Huawei Pronto LTE using an opening tool.
Lift the back cover off of the device after the four corners are unlatched.
Remove the motherboard. Refer to the Motherboard Replacement Guide.
Remove the battery.
거의 끝나갑니다!
결론
