주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The microphone is a important part of the phone that allows it to pick up and record audio. This guide will clearly show you how to remove the microphone without damaging other parts of the phone. Before you start please have the correct tools listed underneath as these tools will ensure a successful microphone replacement.
  1. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front.
    • Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front.
  2. Remove the 15 screws on the back of the phone  with a Phillips #000 screwdriver. Remove the 15 screws on the back of the phone  with a Phillips #000 screwdriver.
    • Remove the 15 screws on the back of the phone with a Phillips #000 screwdriver.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Disconnect the connectors from the motherboard and gently remove the motherboard. Disconnect the connectors from the motherboard and gently remove the motherboard. Disconnect the connectors from the motherboard and gently remove the motherboard.
    • Disconnect the connectors from the motherboard and gently remove the motherboard.
  5. Remove the microphone by lifting it out with the blunt tweezers. Remove the microphone by lifting it out with the blunt tweezers. Remove the microphone by lifting it out with the blunt tweezers.
    • Remove the microphone by lifting it out with the blunt tweezers.
결론
Rylan Abraham
회원 가입일: 2018년 09월 21일
73 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 67
