주요 콘텐츠로 건너뛰기
Huawei Pronto LTE Rear Camera Replacement
필요한 것
  1. Huawei Pronto LTE Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/3 Huawei Pronto LTE Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2/3 Huawei Pronto LTE Rear Camera Replacement, Rear Camera: 1 단계, 이미지 3/3
    • Use an Opening Tool and begin to lever up the back cover of your Huawei Pronto LTE
    • Make sure to do this all around the smartphone.
  2. Huawei Pronto LTE Rear Camera Replacement: 2 단계, 이미지 1/1
    • Remove the back cover.
    • Please keep all the removed smartphone pieces in a safe place. These pieces will be needed later.
  3. Huawei Pronto LTE Rear Camera Replacement: 3 단계, 이미지 1/2 Huawei Pronto LTE Rear Camera Replacement: 3 단계, 이미지 2/2
    • Unscrew the fifteen 0.5mm screws with a Phillips #000 screwdriver.
  4. Huawei Pronto LTE Rear Camera Replacement: 4 단계, 이미지 1/3 Huawei Pronto LTE Rear Camera Replacement: 4 단계, 이미지 2/3 Huawei Pronto LTE Rear Camera Replacement: 4 단계, 이미지 3/3
    • Lift up the connectors with tweezers to disconnect them from the motherboard.
    • Then use the tweezer again to take off the motherboard.
  5. Huawei Pronto LTE Rear Camera Replacement: 5 단계, 이미지 1/2 Huawei Pronto LTE Rear Camera Replacement: 5 단계, 이미지 2/2
    • Release the connector.
    • Loosen the camera from the motherboard and take it out with the tweezers.
    • Do not touch the camera with your hands, only use tweezers.
결론
Sonara
회원 가입일: 09/21/18
171 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 152
