소개
If you are experiencing shutter delay with your Huawei SnapTo G-620's camera, then the camera may need to be replaced. This guide shows you how to replace your SnapTo's camera.
필요한 것
Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
거의 끝나갑니다!
결론
