소개
If you have difficulty being heard clearly on your Huawei SnapTo G-620, then the microphone may need to be replaced. This guide shows you how to replace your SnapTo's microphone.
필요한 것
Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
Use a plastic opening tool to remove the pictured flat-top connector.
Using the plastic opening tool remove the camera.
거의 끝나갑니다!
결론
