주요 콘텐츠로 건너뛰기
Huawei Y300 SIM Card Replacement
필요한 것
  1. Huawei Y300 SIM Card Replacement, Rear Cover: 1 단계, 이미지 1/3 Huawei Y300 SIM Card Replacement, Rear Cover: 1 단계, 이미지 2/3 Huawei Y300 SIM Card Replacement, Rear Cover: 1 단계, 이미지 3/3
    • Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
  2. Huawei Y300 SIM Card Replacement: 2 단계, 이미지 1/1
    • Lift the battery with your finger up and out to remove the battery for replacement.
  3. Huawei Y300 SIM Card Replacement, Replace The Battery: 3 단계, 이미지 1/1
    • After the battery is removed, replace the battery
    • Make sure the battery sits correctly by locating the power output at the bottom left.
  4. Huawei Y300 SIM Card Replacement, SIM Card: 4 단계, 이미지 1/1
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Anthony Ng
회원 가입일: 10/19/14
1,433 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G3
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 24
전체 시간: 4,756
