주요 콘텐츠로 건너뛰기
Huawei u7519 Camera Replacement
필요한 것
  1. Huawei u7519 Camera Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei u7519 Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Camera Replacement: 2 단계, 이미지 1/2 Huawei u7519 Camera Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Camera Replacement: 3 단계, 이미지 1/1
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
    • NOTE: Save the screws. They will be needed for reassembly.
  4. Huawei u7519 Camera Replacement: 4 단계, 이미지 1/1
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • Note: The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Camera Replacement: 5 단계, 이미지 1/1
    • Carefully pull the backing of the phone from the motherboard with your hands.
  6. Huawei u7519 Camera Replacement, Camera: 6 단계, 이미지 1/2 Huawei u7519 Camera Replacement, Camera: 6 단계, 이미지 2/2
    • To remove front encasing from the motherboard, first pull back the orange tabs.
  7. Huawei u7519 Camera Replacement: 7 단계, 이미지 1/2 Huawei u7519 Camera Replacement: 7 단계, 이미지 2/2
    • Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
  8. Huawei u7519 Camera Replacement: 8 단계, 이미지 1/1
    • The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Marcus Mamarella
회원 가입일: 02/13/14
36 평판
안내서 1개 작성함
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014 회원
OSU-MEZA-S14S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 513
