주요 콘텐츠로 건너뛰기
Huawei u7519 Screen Replacement
필요한 것
  1. Huawei u7519 Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Huawei u7519 Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Screen Replacement: 2 단계, 이미지 2개 중 1개 Huawei u7519 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
  4. Huawei u7519 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully pull the backing of the phone from the motherboard with your hands.
  6. Huawei u7519 Screen Replacement, Screen: 6 단계, 이미지 2개 중 1개 Huawei u7519 Screen Replacement, Screen: 6 단계, 이미지 2개 중 2개
    • To remove front case from the motherboard, first pull back the silver tab.
    • Then remove the orange tab.
  7. Huawei u7519 Screen Replacement: 7 단계, 이미지 2개 중 1개 Huawei u7519 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Once the silver and orange tabs are pulled back, carefully pull the motherboard apart from the front case.
  8. Huawei u7519 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Now that the motherboard is separate from the front case, you can discard the original motherboard.
    • The LCD screen can not be removed from the motherboard. Therefore, a new motherboard must be purchased in order to replace this screen.
  9. Huawei u7519 Screen Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • For reassembly:
    • Place the new motherboard on the front case.
    • Snap the tabs back into place.
    • Replace back casing and snap in place.
    • Screw in screws.
    • You can also follow these steps in reverse, which is the same process as outline above.
    • Replacing the power and volume buttons may be tricky. For ease, use tweezers.
    • You have now successfully replaced the screen for the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Alicia
회원 가입일: 02/13/14
34 평판
안내서 1개를 작성함
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014 회원
OSU-MEZA-S14S1G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 866
