주요 콘텐츠로 건너뛰기
Huffy Kids Tricycle Seat Replacement
필요한 것
  1. Huffy Kids Tricycle Seat Replacement, Seat: 1 단계, 이미지 1/2 Huffy Kids Tricycle Seat Replacement, Seat: 1 단계, 이미지 2/2
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: 2 단계, 이미지 1/2 Huffy Kids Tricycle Seat Replacement: 2 단계, 이미지 2/2
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: 3 단계, 이미지 1/3 Huffy Kids Tricycle Seat Replacement: 3 단계, 이미지 2/3 Huffy Kids Tricycle Seat Replacement: 3 단계, 이미지 3/3
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: 4 단계, 이미지 1/3 Huffy Kids Tricycle Seat Replacement: 4 단계, 이미지 2/3 Huffy Kids Tricycle Seat Replacement: 4 단계, 이미지 3/3
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: 5 단계, 이미지 1/3 Huffy Kids Tricycle Seat Replacement: 5 단계, 이미지 2/3 Huffy Kids Tricycle Seat Replacement: 5 단계, 이미지 3/3
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: 6 단계, 이미지 1/2 Huffy Kids Tricycle Seat Replacement: 6 단계, 이미지 2/2
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
결론
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
Babatunde Adewunmi
회원 가입일: 09/18/21
222 평판
안내서 1개 작성함
York University, Team F-4, Woodhouse Fall 2021 York University, Team F-4, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 596
