주요 콘텐츠로 건너뛰기
Huntington GA41PS-RDS Acoustic Guitar String Replacement
필요한 것
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: 1 단계, 이미지 1/1
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 2 단계, 이미지 1/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 2 단계, 이미지 2/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 2 단계, 이미지 3/3
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 3 단계, 이미지 1/2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 3 단계, 이미지 2/2
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 4 단계, 이미지 1/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 4 단계, 이미지 2/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 4 단계, 이미지 3/3
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 5 단계, 이미지 1/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 5 단계, 이미지 2/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 5 단계, 이미지 3/3
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 6 단계, 이미지 1/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 6 단계, 이미지 2/3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 6 단계, 이미지 3/3
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 7 단계, 이미지 1/2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 7 단계, 이미지 2/2
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
결론
Ruhail Khan
회원 가입일: 01/18/22
145 평판
안내서 1개 작성함
York University, Team R-15, Melo-Thaiss Winter 2022 York University, Team R-15, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG15
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 369
