주요 콘텐츠로 건너뛰기
Husqvarna FE 350 Rear Sprocket Replacement
필요한 것
  1. Husqvarna FE 350 Rear Sprocket Replacement, Rear Sprocket: 1 단계, 이미지 1/1
    • Place the motorcycle on a stand so that the rear tire is off the ground.
  2. Husqvarna FE 350 Rear Sprocket Replacement: 2 단계, 이미지 1/2 Husqvarna FE 350 Rear Sprocket Replacement: 2 단계, 이미지 2/2
    • Use the 27mm wrench to unscrew the nut that holds the axle together. This nut is located on the right side of the motorcycle at the end of the swing-arm.
  3. Husqvarna FE 350 Rear Sprocket Replacement: 3 단계, 이미지 1/3 Husqvarna FE 350 Rear Sprocket Replacement: 3 단계, 이미지 2/3 Husqvarna FE 350 Rear Sprocket Replacement: 3 단계, 이미지 3/3
    • Move to the left side of the motorcycle and remove the axle by pulling it directly out.
    • Move back to the right side and remove the spacer shown in the third picture to ensure that is does not get lost.
  4. Husqvarna FE 350 Rear Sprocket Replacement: 4 단계, 이미지 1/2 Husqvarna FE 350 Rear Sprocket Replacement: 4 단계, 이미지 2/2
    • Pull up and back on the chain to free the tire.
  5. Husqvarna FE 350 Rear Sprocket Replacement: 5 단계, 이미지 1/1
    • Lay the tire on a flat surface with with sprocket facing up.
    • Use the 6mm Torx wrench to unscrew the six bolts holding the sprocket on.
    • Replace the sprocket and screw the bolts back in.
  6. Husqvarna FE 350 Rear Sprocket Replacement: 6 단계, 이미지 1/1
    • Be careful that the brake rotor fits in between the brake pads on the caliper.
  7. Husqvarna FE 350 Rear Sprocket Replacement: 7 단계, 이미지 1/1
    • Put the chain back on. Start at the bottom and work the chain carefully over the top of the new sprocket.
  8. Husqvarna FE 350 Rear Sprocket Replacement: 8 단계, 이미지 1/3 Husqvarna FE 350 Rear Sprocket Replacement: 8 단계, 이미지 2/3 Husqvarna FE 350 Rear Sprocket Replacement: 8 단계, 이미지 3/3
    • Push the axle back through the swing arm and the wheel.
    • Place the spacer back onto the axle with the square side pointing forward.
    • Thread the 27mm nut back onto the axle.
  9. Husqvarna FE 350 Rear Sprocket Replacement: 9 단계, 이미지 1/1
    • Use the 27mm wrench to tighten the nut down.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Bryce Marking
회원 가입일: 02/02/21
231 평판
안내서 1개 작성함
댓글 한 개
C'est bien. je veux apprendre à réparer les motos
Enoch DEMBELE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 61
전체 시간: 989
