주요 콘텐츠로 건너뛰기
Husqvarna Trimmer Carburetor Replacement
필요한 것
  1. Husqvarna Trimmer Carburetor Replacement, Husqvarna Trimmer Carburetor: 1 단계, 이미지 1/1
    • Allow time for the engine to cool before beginning this procedure.
    • Using your fingers, unscrew the air filter bolt and remove it from the filter cover.
  2. Husqvarna Trimmer Carburetor Replacement: 2 단계, 이미지 1/3 Husqvarna Trimmer Carburetor Replacement: 2 단계, 이미지 2/3 Husqvarna Trimmer Carburetor Replacement: 2 단계, 이미지 3/3
    • Pull off the filter cover to reveal the air filter.
    • Remove the air filter from the filter housing.
  3. Husqvarna Trimmer Carburetor Replacement: 3 단계, 이미지 1/2 Husqvarna Trimmer Carburetor Replacement: 3 단계, 이미지 2/2
    • Remove two 8mm nuts with an 8mm socket attached to a 1/4" ratchet turning the nuts counterclockwise.
  4. Husqvarna Trimmer Carburetor Replacement: 4 단계, 이미지 1/2 Husqvarna Trimmer Carburetor Replacement: 4 단계, 이미지 2/2
    • Slide the choke lever to the full choke position.
  5. Husqvarna Trimmer Carburetor Replacement: 5 단계, 이미지 1/3 Husqvarna Trimmer Carburetor Replacement: 5 단계, 이미지 2/3 Husqvarna Trimmer Carburetor Replacement: 5 단계, 이미지 3/3
    • Remove the plastic housing by pulling it away from the device.
  6. Husqvarna Trimmer Carburetor Replacement: 6 단계, 이미지 1/2 Husqvarna Trimmer Carburetor Replacement: 6 단계, 이미지 2/2
    • Pull the carburetor off of the bolts.
  7. Husqvarna Trimmer Carburetor Replacement: 7 단계, 이미지 1/3 Husqvarna Trimmer Carburetor Replacement: 7 단계, 이미지 2/3 Husqvarna Trimmer Carburetor Replacement: 7 단계, 이미지 3/3
    • Detach the throttle cable from the carburetor by tilting it 90 degrees and pulling up.
  8. Husqvarna Trimmer Carburetor Replacement: 8 단계, 이미지 1/2 Husqvarna Trimmer Carburetor Replacement: 8 단계, 이미지 2/2
    • Remove the two fuel lines attached to the bottom of the carburetor using a set of needle nose pliers.
    • Gas may splash when removing fuel lines.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Antonio Lopez
회원 가입일: 02/20/19
175 평판
안내서 1개 작성함
University of Memphis, Team S2-G1, Baddour Spring 2019 University of Memphis, Team S2-G1, Baddour Spring 2019 회원
UM-BADDOUR-S19S2G1
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 55
전체 시간: 1,881
