소개
The purpose of this guide is to aid any owner of a Husqvarna Trimmer in the replacement of their gas line chamber. While the replacement process is rather straight forward and no special skills are required, it is still important for one to take caution when dealing with fuel. Be sure to use the right fuel for the Husqvarna trimmer, as all fuels are not the same. When finished or spilling occurs, stop and make sure your area and person are fully removed from the fuel before continuing on other tasks.
필요한 것
Detach the hoses of the gas line from the carburetor using the needle nose pliers.
For the second line, use a pair of sharp edge scissors to cut the remainder of the gas line from the gas tank.
Remove the remainder of the gas line using your hands and ensure it comes out completely leaving no gas line residue.
Gather filter attachment kit.
Gather the hoses that most closely resemble the size of the hose previously taken out.
Connect the filter attachment (provided in the kit) to the hose.
Use the metal wire, provided in the kit to guide the new tube through the hole of the gas tank.
Ensure that the wire comes out of the inlet of the gas tank.
Hook the end of the gas line to the wire, so that the wire can be pulled and feed the wire through the hole.
Keep pulling the gas line through the hole until the gas lines are long enough to meet the tubes on the carburetor.
Pull out the hoses until they fit the pipes in the carburetor. Using the needle nose pliers.
다른 한 분이 해당 안내서를 완성하였습니다.
