주요 콘텐츠로 건너뛰기
Hydration Bladder Leak Repair
필요한 것
  1. Hydration Bladder Leak Repair, Hydration Bladder Leak Repair: 1 단계, 이미지 1/1
    • Remove the hydration bladder from inside the backpack.
  2. Hydration Bladder Leak Repair: 2 단계, 이미지 1/1
    • Check the bladder and pipe to locate any scratches or leaks.
    • It may help to fill the bladder up with water to check for additional tiny leaks which could be harder to locate than leaks on the pipe.
  3. Hydration Bladder Leak Repair: 3 단계, 이미지 1/1
    • Rinse out the pipe to clear any clogs.
  4. Hydration Bladder Leak Repair: 4 단계, 이미지 1/1
    • Cut appropriate size tenacious tape to patch the leak on the bladder.
  5. Hydration Bladder Leak Repair: 5 단계, 이미지 1/1
    • Seal the leak on the bladder with tenacious tape.
    • Do not try to use regular tape as it will not seal correctly.
    • Smooth out all the edges and apply pressure for approximately one to two minutes.
  6. Hydration Bladder Leak Repair: 6 단계, 이미지 1/1
    • Slide the heat shrink tube over the pipe and hold tightly in place over the ruptured area.
  7. Hydration Bladder Leak Repair: 7 단계, 이미지 1/2 Hydration Bladder Leak Repair: 7 단계, 이미지 2/2
    • Using a hair dryer, apply heat to shrink the tube until it is tightly sealed in place.
    • This process may take 20-35 minutes depending on the power of your heat source.
  8. Hydration Bladder Leak Repair: 8 단계, 이미지 1/1
    • Reinsert the pipe back into the bladder and twist lock it back into place as shown.
    • Make sure you feel it snap back into place and listen for a "click" sound.
  9. Hydration Bladder Leak Repair: 9 단계, 이미지 1/1
    • Slide the bladder itself back into backpack and pull the pipe out through the opening as indicated and your bag is good to go!
결론
다른 3명이 해당 안내서를 완성하였습니다.
Magnolia Garcia
회원 가입일: 10/26/18
178 평판
안내서 1개 작성함
UC Davis, Team S2-G7, Bender Fall 2018 UC Davis, Team S2-G7, Bender Fall 2018 회원
UCD-BENDER-F18S2G7
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 25
30일 전: 111
전체 시간: 9,864
