주요 콘텐츠로 건너뛰기
Hydrotech 89-series Control Valve Injector Replacement
필요한 것
  1. Hydrotech 89-series Control Valve Injector Replacement, Preparing the Hydotech 89-series control valve for repair.: 1 단계, 이미지 3개 중 1개 Hydrotech 89-series Control Valve Injector Replacement, Preparing the Hydotech 89-series control valve for repair.: 1 단계, 이미지 3개 중 2개 Hydrotech 89-series Control Valve Injector Replacement, Preparing the Hydotech 89-series control valve for repair.: 1 단계, 이미지 3개 중 3개
    • Locate the RED bypass knobs.
    • Using an allan key or a pair of pliers, turn the knobs so the stamped arrows are facing each other.
    • CAUTION: The bypass knobs may become detached, if this happens take note of the position of the knob and return the knob to that position and press down to reseat it.
  2. Hydrotech 89-series Control Valve Injector Replacement: 2 단계, 이미지 2개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 2 단계, 이미지 2개 중 2개
    • IMPORTANT: Verify the valve is in bypass before proceeding.
  3. Hydrotech 89-series Control Valve Injector Replacement: 3 단계, 이미지 2개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 3 단계, 이미지 2개 중 2개
    • Unlock the valve.
    • Press and hold the {MENU} key until the valve beeps/the padlock icon disappears.
  4. Hydrotech 89-series Control Valve Injector Replacement: 4 단계, 이미지 3개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 4 단계, 이미지 3개 중 2개 Hydrotech 89-series Control Valve Injector Replacement: 4 단계, 이미지 3개 중 3개
    • Activate manual regeneration
    • After the valve is unlcoked, press the [MENU] button once more to bring up a menu prompt.
    • Repeatedly press the {DOWN] button until "Manual Regen" is selected.
    • Press Set
    • Use the [UP} arrow to select "Regen Now" and press {SET} to begin the regeneration process.
  5. Hydrotech 89-series Control Valve Injector Replacement: 5 단계, 이미지 2개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 5 단계, 이미지 2개 중 2개
    • Press and hold any button for approximately 3 seconds to skip ahead, do this until the valve is in either BACKWASH or RINSE.
    • Wait until the time begins to count down to ensure it is has relieved pressure
    • Note: If you have a Downflow valve or are using this valve on a filter your first regeneration cycle will be BACKWASH, you won't need to skip ahead.
    • Note: The valve may take a couple of minutes to move between cycles, please be patient with it.
    • Finally, disconnect the valve from the power supply by unplugging the 12v A/C adapter from the wall.
  6. Hydrotech 89-series Control Valve Injector Replacement, Injectors: 7 단계, 이미지 3개 중 1개 Hydrotech 89-series Control Valve Injector Replacement, Injectors: 7 단계, 이미지 3개 중 2개 Hydrotech 89-series Control Valve Injector Replacement, Injectors: 7 단계, 이미지 3개 중 3개
    • Removing the Injector Cover (A36)
    • Remove the two #2 Phillips screws (A4) from the injector cover (A36) and remove with your fingers.
  7. Hydrotech 89-series Control Valve Injector Replacement: 8 단계, 이미지 2개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the Injector Screen (A37) using your fingers or a pair of tweezers.
    • Note: In most cases this part may be gently cleaned rather than replaced.
  8. Hydrotech 89-series Control Valve Injector Replacement: 9 단계, 이미지 3개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 9 단계, 이미지 3개 중 2개 Hydrotech 89-series Control Valve Injector Replacement: 9 단계, 이미지 3개 중 3개
    • Remove Injector Nozzle (A33)
    • Using a 1/4" flat blade screwdriver, turn the Injector Nozzle counterclockwise to unscrew.
  9. Hydrotech 89-series Control Valve Injector Replacement: 10 단계, 이미지 2개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 10 단계, 이미지 2개 중 2개
    • Remove Injector Throat (A31)
    • Using a 3/16 Flat Blade screwdriver (or iFixit #4 flat blade bit) turn the injector throat counterclockwise to unscrew.
    • Using a pair of reverse tweezers, remove the injector throat.
  10. Hydrotech 89-series Control Valve Injector Replacement: 11 단계, 이미지 2개 중 1개 Hydrotech 89-series Control Valve Injector Replacement: 11 단계, 이미지 2개 중 2개
    • REASSEMBLY
    • To reassemble, insert the injector throat, injector nozzle and injector screen in reverse order of removal.
    • Prior to reinstalling the Injector Cover (A36) and reinstalling the screws, apply a layer of silicone grease to the o-ring (A35), this will allow the o-ring to reseal to the valve body properly.
결론
You have successfully replaced (or cleaned) the Injectors in your Hydrotech 89-series Control Valve.
You may now party on!
작성자
2다른 기여자 명과 함께
N. T. Crotser
회원 가입일: 06/13/22
928 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 24
전체 시간: 492
