주요 콘텐츠로 건너뛰기
Hyggly Percussive Massage Gun Battery Replacement
필요한 것
  1. Hyggly Percussive Massage Gun Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the 4 rubber stoppers on the massage gun.
    • You can use tweezers for ease or take the hard way and use your screwdriver.
  2. Hyggly Percussive Massage Gun Battery Replacement: 2 단계, 이미지 2개 중 1개 Hyggly Percussive Massage Gun Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, unscrew the 1 Phillips head screw underneath the power button.
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws under the rubber stopper.
  3. Hyggly Percussive Massage Gun Battery Replacement: 3 단계, 이미지 2개 중 1개 Hyggly Percussive Massage Gun Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Twist and remove the circular black lid that houses the main circuit board.
    • Pull apart the main body of the massage gun. The gun should now be in three parts.
    • Detach the wires connected to the main circuit board.
    • Remember to write down which wire attaches where.
  4. Hyggly Percussive Massage Gun Battery Replacement: 4 단계, 이미지 2개 중 1개 Hyggly Percussive Massage Gun Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws inside the main body of the massage gun.
    • Pry open the lid once the screws are removed.
  5. Hyggly Percussive Massage Gun Battery Replacement: 5 단계, 이미지 2개 중 1개 Hyggly Percussive Massage Gun Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the top cover from battery compartment.
    • Remove the rubber sleeve off the battery compartment.
  6. Hyggly Percussive Massage Gun Battery Replacement: 6 단계, 이미지 2개 중 1개 Hyggly Percussive Massage Gun Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the sticker off the bottom of the battery compartment near the power switch.
    • Using the Phillips #00 screwdriver, unscrew the 3 Phillips head screws around the power switch to access the inside of the battery compartment.
  7. Hyggly Percussive Massage Gun Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the bottom lid of the battery compartment to reveal the second circuit board.
    • Detach the wires of the battery from the circuit board.
    • Remember to write down the positioning of the wires.
  8. Hyggly Percussive Massage Gun Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Pry open the battery compartment
  9. Hyggly Percussive Massage Gun Battery Replacement: 9 단계, 이미지 2개 중 1개 Hyggly Percussive Massage Gun Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the old battery to replace the new one.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Raj Patel
회원 가입일: 09/15/23
223 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 180
전체 시간: 2,401
