주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HyperX KHX-HSCP-GM Cloud II jack plug replacement
필요한 것
  1. HyperX KHX-HSCP-GM Cloud II jack plug replacement, Soldering: 1 단계, 이미지 3개 중 1개 HyperX KHX-HSCP-GM Cloud II jack plug replacement, Soldering: 1 단계, 이미지 3개 중 2개 HyperX KHX-HSCP-GM Cloud II jack plug replacement, Soldering: 1 단계, 이미지 3개 중 3개
    • Prepare the Soldering Iron: Plug in and heat up your soldering iron. Ensure it's clean and ready for use.
    • Remove the Old Plug: Carefully cut away the old jack plug if it is still attached. Use wire strippers to expose the wires inside the cable.
    • Tin the Wires: Lightly tin the exposed wire ends by applying a small amount of solder. This makes it easier to connect to the new jack plug.
    • Attach the Wires to the New Plug: Identify the corresponding terminals on the new 3.5mm 4-pole jack plug (ground, left, right, microphone). Solder each tinned wire to its corresponding terminal.
    • Inspect the Connections: Double-check the solder joints to ensure they are secure and that no wires are crossing or shorting out.
    댓글 쓰기
  2. HyperX KHX-HSCP-GM Cloud II jack plug replacement, shrink tubing: 2 단계, 이미지 3개 중 1개 HyperX KHX-HSCP-GM Cloud II jack plug replacement, shrink tubing: 2 단계, 이미지 3개 중 2개 HyperX KHX-HSCP-GM Cloud II jack plug replacement, shrink tubing: 2 단계, 이미지 3개 중 3개
    • Prepare the Heat Shrink Tubing: Select an appropriate size of heat shrink tubing that will fit over the soldered connections and the base of the plug.
    • Slide Tubing Over the Wires: Before fully assembling the plug, slide the heat shrink tubing over the wires and position it near the soldered connections.
    • Apply Heat: Use a heat gun or the side of the soldering iron to gently heat the tubing until it shrinks tightly around the wires, providing insulation and strain relief.
    • Reassemble the Plug: Once the tubing has been shrunk, carefully reassemble the plug casing over the soldered connections.
    • Test the Connection: Plug the jack into a compatible device to ensure that all connections (audio and microphone) work as intended.
    댓글 쓰기
결론
Reverse the Disassembly Process: Follow the steps in reverse order to fully reassemble your device. Ensure everything is securely in place and that no components are left loose.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Prokrastinator
회원 가입일: 08/18/17
386 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 57
전체 시간: 1,311
