소개
If your microphone has any distortion in tone, such as the audio being too quiet, or too loud, then there may be a problem with the gain control knob. This guide will demonstrate how to simply remove the gain control knob, which can allow access to the I/O board of the microphone. Keep in mind that this guide highlights removing the gain control knob, and not how to remove the I/O board.
Set the microphone on a flat surface.
Pull each of the support bands upwards and off of the notches to release the microphone from its base.
다른 한 분이 해당 안내서를 완성하였습니다.
