주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hyperkin Retron 3 Disassembly
필요한 것
  1. Hyperkin Retron 3 Disassembly, Remove 6 screws loacted on the bottom of the system: 1 단계, 이미지 1개 중 1개
    • First and foremost, be sure to unplug both power and AV/S-Video cables and remove any games that may be plugged into the console.
    • In order to get into the system you're going to have to remove the 4 rubber boots on the bottom of the console in order to access 4 hidden screws underneath. The other two screws are already accessible.
    • These rubber boots are cheap and not easily reusable if they become stuck to each other or other items. I completely removed mine and because they weren't reattached right away they became stuck to each other and trying to pull them apart causes them to rip. In my case, I'm not particularly concerned if they are there or not and replacements
    • shouldn't be hard to find online I'd imagine.
    • If you'd like to avoid removing the boots utilize the picture provided to simply poke your screw driver threw the boot where the screw would be located. It might be tricky as you're looking for the only circle surrounded by several squares.
  2. Hyperkin Retron 3 Disassembly, Lift top half of system shell: 2 단계, 이미지 2개 중 1개 Hyperkin Retron 3 Disassembly, Lift top half of system shell: 2 단계, 이미지 2개 중 2개
    • DO NOT ATTEMPT TO COMPLETELY SEPARATE THE TWO HALVES AS THEY ARE CONNECTED VIA THE SYSTEM SWITCH DIAL ON THE UPPER SHELL AND THE MAIN PCB.
    • The cables have been glued down at the connection points as well. The upper shell and PCB unit don't need to be completely separated in order to get in and repair the system although it would make it easier.
    • Unless you are confident in removing this glue without causing damage and your soldering skills I don't advise trying to separate the two.
  3. Hyperkin Retron 3 Disassembly, Remove screws securing the PCBs to lower shell: 3 단계, 이미지 1개 중 1개
    • I find it easiest to prop up the top shell on the front right corner of the system. If you're using a flat surface it can stand by itself and there's enough slack in the Genesis PCB and Dial Switch cables to allow it to be positioned in such a way.
    • You can barely see it but the upper shell is standing upright on the front right corner.
    • There are 11 screws that need to be removed in order to remove the entire PCB unit.
    • If the IR lens cover pops out at this point don't worry about it. It can be easily reinstalled during the reassembly process.
  4. Hyperkin Retron 3 Disassembly, Remove PCBs from lower shell: 4 단계, 이미지 2개 중 1개 Hyperkin Retron 3 Disassembly, Remove PCBs from lower shell: 4 단계, 이미지 2개 중 2개
    • The top shell won't be far away during this repair. Find a few objects to keep it upright or out of your way.
    • The AV/Power/NES PCB will be the last to remove during disassembly and first to replace during reassembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Navy Vet 2015
회원 가입일: 06/25/15
8,177 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 121
전체 시간: 3,857
