이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to properly open up your Hyperkin Retron 3 console in the event you need to make repairs.
필요한 것
In order to get into the system you're going to have to remove the 4 rubber boots on the bottom of the console in order to access 4 hidden screws underneath. The other two screws are already accessible.
You can barely see it but the upper shell is standing upright on the front right corner.
There are 11 screws that need to be removed in order to remove the entire PCB unit.
The AV/Power/NES PCB will be the last to remove during disassembly and first to replace during reassembly.
다른 2명이 해당 안내서를 완성하였습니다.
