주요 콘텐츠로 건너뛰기
Hytera TC-580 Keypad Replacement
필요한 것
  1. Hytera TC-580 Keypad Replacement, Battery: 1 단계, 이미지 1/2 Hytera TC-580 Keypad Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Keypad Replacement: 2 단계, 이미지 1/2 Hytera TC-580 Keypad Replacement: 2 단계, 이미지 2/2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Keypad Replacement, Antenna: 3 단계, 이미지 1/1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Keypad Replacement, Keypad: 4 단계, 이미지 1/1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Keypad Replacement: 5 단계, 이미지 1/1
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Keypad Replacement: 6 단계, 이미지 1/1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Keypad Replacement: 7 단계, 이미지 1/1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Keypad Replacement: 8 단계, 이미지 1/2 Hytera TC-580 Keypad Replacement: 8 단계, 이미지 2/2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Keypad Replacement: 9 단계, 이미지 1/1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Keypad Replacement: 10 단계, 이미지 1/1
    • Peel off the keypad by hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stuart
회원 가입일: 02/14/18
464 평판
안내서 3개 작성하였습니다
USF Tampa, Team S3-G4, Nance Spring 2018 USF Tampa, Team S3-G4, Nance Spring 2018 회원
USFT-NANCE-S18S3G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 333
