주요 콘텐츠로 건너뛰기
Hytera TC-580 Speaker Replacement
필요한 것
  1. Hytera TC-580 Speaker Replacement, Battery: 1 단계, 이미지 1/2 Hytera TC-580 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: 2 단계, 이미지 1/2 Hytera TC-580 Speaker Replacement: 2 단계, 이미지 2/2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: 3 단계, 이미지 1/1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: 4 단계, 이미지 1/1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: 8 단계, 이미지 1/2 Hytera TC-580 Speaker Replacement: 8 단계, 이미지 2/2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: 9 단계, 이미지 1/1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: 10 단계, 이미지 1/1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: 11 단계, 이미지 1/3 Hytera TC-580 Speaker Replacement, Speaker: 11 단계, 이미지 2/3 Hytera TC-580 Speaker Replacement, Speaker: 11 단계, 이미지 3/3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: 12 단계, 이미지 1/1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
결론
Mohammed Chehab
회원 가입일: 02/14/18
88 평판
안내서 1개 작성함
USF Tampa, Team S3-G4, Nance Spring 2018 USF Tampa, Team S3-G4, Nance Spring 2018 회원
USFT-NANCE-S18S3G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 493
