주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Hyundai H-150 수리는 저희 서비스 설명서를 사용하십시오.
  1. Hyundai H-150 Teardown, Hyundai H-150 Teardown: 1 단계, 이미지 1/3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: 1 단계, 이미지 2/3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: 1 단계, 이미지 3/3
    • We'll start with a preview of the phone. Front, back and side view are shown here.
  2. Hyundai H-150 Teardown: 2 단계, 이미지 1/3 Hyundai H-150 Teardown: 2 단계, 이미지 2/3 Hyundai H-150 Teardown: 2 단계, 이미지 3/3
    • The battery is removed easily. Just pull down the part from the back and the battery goes out.
  3. Hyundai H-150 Teardown: 3 단계, 이미지 1/3 Hyundai H-150 Teardown: 3 단계, 이미지 2/3 Hyundai H-150 Teardown: 3 단계, 이미지 3/3
    • After the battery is out, we're presented with a plastic cover with all the phone's information (Model No., Serial No etc)
    • Notice the 4 Philips screw-heads in each of the four corners. Those need to go off.
    • After unscrewing, you might notice that the cover doesn't easily go off. Four clips are holding the back cover onto the front cover.
    • Use a Spudger and unclip the sides of the cover. It shouldn't put up much resistance
  4. Hyundai H-150 Teardown: 4 단계, 이미지 1/3 Hyundai H-150 Teardown: 4 단계, 이미지 2/3 Hyundai H-150 Teardown: 4 단계, 이미지 3/3
    • Once the back cover is off, one can see the motherboard and a strange metal part on the top of the phone. This serves as an antenna booster, but also to protect the board.
  5. Hyundai H-150 Teardown: 5 단계, 이미지 1/3 Hyundai H-150 Teardown: 5 단계, 이미지 2/3 Hyundai H-150 Teardown: 5 단계, 이미지 3/3
    • See that hole in the shield? That Has a screw in it. And yes, it needs to leave.
    • After removing the screw from the shield, it can be lifted from the board easily, revealing another board beneath it.
  6. Hyundai H-150 Teardown: 6 단계, 이미지 1/3 Hyundai H-150 Teardown: 6 단계, 이미지 2/3 Hyundai H-150 Teardown: 6 단계, 이미지 3/3
    • It seems that this secondary board is held onto the main board by a board connector.
    • Pull the board gently and you'll notice it comes out rather fast.
  7. Hyundai H-150 Teardown: 7 단계, 이미지 1/3 Hyundai H-150 Teardown: 7 단계, 이미지 2/3 Hyundai H-150 Teardown: 7 단계, 이미지 3/3
    • By this stage, the board simply comes out of the front body, exposing the keyboard and its associated membrane.
    • On the board we encounter the ringer(upper left), the headphone/handsfree input(under the ringer) and the LCD (which is sadly sticked on the board, as is the keypad membrane)
    • On the case we encounter the microphone (lowest part of the phone case), the loudspeaker (the highest part of the phone case)
  8. Hyundai H-150 Teardown: 8 단계, 이미지 1/2 Hyundai H-150 Teardown: 8 단계, 이미지 2/2
    • That concludes the teardown for now.
Nicolay
회원 가입일: 04/08/13
371 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 819
